96 Ls400 wiring problem.
brian3663
Hi Guys, stripping a 96 Ls400 for racing, wiring wise all i need is ignition and fuel injection,i've been taking out wires with the engine running but after switching off it will not run for more than a few seconds,
the dash has been removed and the wiring loom has been opened to expose all the wires, i believe the security system may have kicked in,
question 1, where can i get a complete wiring diagram especially of the main ecu,
2) is there a way around the ignition switch,(not needed)
3)what manual gearbox and flywheel will fit?
thanks in advance,
brian.
