Ok so I bought a 94 sc400 for cheap just as a work car to restore over time however I can not seem to get it running properly enough to drive yet here is the story.....
217k miles compression and leak down is within range fuel pump ecu works as it should did the bypass just to eliminate that as a problem.
I bought it from a redneck pick up truck "shop" that was far out of there element and gave up on the car I bought it home and threw a battery and fresh gas in and it started after sitting for 3 years but ran with a misfire so I did plugs,wires,and new coils as one on the drivers side was bad so I changed them in pairs.
now the car has an odd misfire and backfires through the intake and wont rev over 2k rpm unless you feather the gas at partial throttle to get it to 3500 ish rpm then it will rev clean to rev limit sometimes also the car runs very rich so I noticed this morning upon cold start it will make a clean rev and sounds healthy as can be until it warms up and this clean rev sweep was with the maf tube unhooked from the throttle body and maf so runs good until comes up to temp.
I have changed the coolant temp sensors and caps and rotors as well as sent the ecu to tannin auto for a rebuild which they did the new caps although they did not appear to be leaking visually.
it is showing a maf code from being unplugged and a #1 knock sensor code which I do not think it can cause all of these issues?
I am at a loss on this one does anyone have any ideas or is there anything I have overlooked?
