OK, I took on a friends 93 SC400. While he was driving home, he overheated it (temp was at H), the water pump seized, the idler pulley burst and sagged, which allowed the tattered belt to slip off. The car shut itself down right in front of his driveway and would not start again....
Anyway, he asked me to swap the water pump and timing belt. Everything went smoothly with the water pump, and timed my marks with CR to the small dot on the crank, Left to the left cam, Right to the right cam, then tightened the tensioner. Everytime I bring it to TDC, the engine and cam marks line up, I put the rotor in correctly, compression is 200-210 everywhere, I am getting spark, injectors get signal, even jumped the fuel pump to make sure it was working (Fp+B) and yet the car will not fire up. (I am getting code 24-Intake temp sensor, and the AFM is plugged in)
HELP!!! Looks like it might have to go to the shop unless a Guru here can help.
Thanks to anyone in advance
