mysticmicheline
1993 LS400 battery replaced, no lights and wont shift out of park
OK, long story as short and sweet as I can make it.
Started off with a weird battery drain, jumping it off about once a week, then the battery was less than 10 volts, so i tried another battery, ( I might have accidentally reversed the polarity) it would only crank but not start so that didn't work, so I reconditioned and charged the original battery, put it in and it started right up....
problem is no lights ANYWHERE, all I have is horn and hazards. It also wont shift out of park.
I was advised to replace the 120 alt amp cartridge fuse. done. still no lights anywhere and I've called myself checking the other 3 fuses that it "could be", to no avail.
I'm in no position to "throw parts at it, and I'm at a loss, PLEASE HELP.
