Hi i'm new on here and just needed a bit of help with wiring a 1uzfe out of a 92 ls400. I have the whole car and have been going through the loom cutting out what i don't need but i'm a bit stuck with the 28 pin connector into ecu and 16 pin grey connector that plugs into ecu harness.
The 28 pin i have right (i think) i have 5 wires into it, 1 blk/yel wire which is permenant 12v, then 2 blk/red wires and 2 blk/org 1 smaller than the other. Not too sure which pins are what though.
then my 16pin connector i have a large black for starter power and a blk/wht for starter solenoid, then i have a large blk/org, a blk/red and a blk. These all need to be connected for it to run.
the eng and ecu are still in the car so i wanted to get it all running with loom figured out before swapping into another car. The other issue i have is the theft computer. If i unplug it, it won't start the car. Will this be an issue once i take external power supplys for batt, ign and starter relays?
Any help appriciated.
