i bought a motor out of the junkyard and need a wiring harness and/or ecu. i can find the ecu locally. no luck on the harness.
mine is cut just after the rubber grommet for the firewall. the wiring harness is the most important item. if you have the plugs for the ecu side with a decent amount of wiring, ill take that too. let me know what you have. Thanks
