Parts 91 1uzfe,r154 transmission and dellow kit
o5mar1
well it looks like im not going to finish this swap so im going to sell all my swap parts i have..
the engine is a 91 sc400 engine, it has a new timing belt,timing belt tensioners and pulleys,water pump,spark plugs valve cover gaskets.it also has the ls400 fan
bracket with pulley.i have both front and rear sump oil pans with pick up tubes.I was going to use megasquirt and ford edis ignition system so the engine dosent
have the distributors or spark plug wires.i have the complete engine harness uncut and alternator.
The transmission is a r154 off of a turbo supra no leaks, and i have a complete dellow automotive kit minus the spedo cable.. i allready put the ring gear on to the flywheel. you can go to www.dellowauto.com.au to see whats included.I onlly test fitted the conversion parts on to the transmission and engine to make sure they fit.. I am located in san diego california and i dont really want to deal with shipping... im asking 2500 for everything
here are some photos i have of the stuff
i can be reached by email its [email protected]
