'89 surf 4x4 wiring
warny
The little motor in the back of the transfercase (engages 4x4) on our surf isnt getting power. Anyone know where its ment to come from? where can i find a wiring diagram? Been tryin to find an answer for ages- with no luck. Cheers in advance
best of searching the forums for an aftermarket wiring diagram to get the transfer motor to work
they use 4 or 6 relays
someone on here will come up with the link if yr lucky
the surf has a 2nd ecu it runs the auto and the 4wd
so if u have converted to a 1uz then u need to sort out what to do
if its a factory surf u need to find the auto ecu
or the 4wd ecu if its a manual
auto ecu is right habd kick panel
i think 4wd ecu if its a manual is centre of dash at bottom
not to sure
if u want a manual one find a landcruiser or 4 runner of simialr age
it might be ok
if i looked at it i could esily figure it out as ive played with these units many times when doing landcruiser converisons
anyway how are you going to get the motor to work
u will need a special relay and switch to get it to work
or u can use the 6 relay setup someone on here has devised
so 1st decide what u have and which way u want to control it
if u send me motor over i could set it all up for u with the correct 4wd relay and switches
otherwise find someone in yr side of the world that has played with surfs
but if u have nothing
there is no straight forward fix
