5.7L tundra 8psi
wishmaster
Hi,
where i can fined bigger size crank pulley for TRD supercharge on my toyota tundra !! or smaller charger pulley ?!
max boost i got is 5psi !! i am shooting to get atleast 8psi could you help me where to get them ?
also what you think about lextreme custom grind blower cam !!? what could be the gain ? and do any member here try it ?
my car is toyota tundra 5.7L with trd S/C,header,uni chip
Rgrd
We havent sold any 5.7L cams yet. Cores are hard to find. We regrind and increase lash thickness. The oem valves use lash caps. I would contact Eaton for the pulley other aftermarket should work.
thanks man,do you know which size of pulley should i go with ?!! i dont need the boost jump over 10psi !!
and for the cam shaft have you try these blower cam ?!
I would go perhaps .10 to .20" undersize and no we havent try on the blower cams yet.
