I've just picked my truck up from being wired, everything is working accept the stock tacho, the hilux originally had a 22r in it, so I would have thought it would work fine. But it doesn't even seem to get any signal. It is wired in but I’m not sure what to.
The guy that wired it said it may need the signal changed; he also tried using the coil of a relay inline to get it to work with no luck.
After reading this I'm wondering if it's wired into the wrong part of the igniters.
"simply get a petrol hilux cluster and then wired it into one of the coil negitives.
I believe the link will not fire the factory carburetted petrol tacho with ign3 as the factory signal is direct from the coil. As each coil only fire 4 cylinders this works perfectly"
