Hello
Well we have yet another conversion to do. This one is for a customer from Auckland New Zealand( about an hour north of my shop) who wants a single cab 1994 LN106R hilux fitted with a 1UZ. He requested that it be fully road legal to comply with the class he wants to compete in and it's alot more fun if it can be driven to work.
The ute already has had the exterior painted and a suspension lift with springs and EFS shocks. In the photos we have lifted the body 40mm. The customer supplied the body lift kit which was meant to be 50mm but the supplier got it wrong but reduced the price so the kit was kept and we fitted it. Of coarse we removed the 3L which was the factory equipment. We are sticking with the G52 gearbox and transfer box. The complete ute is quite tidy which always makes a conversion nicer to do.
Some of you may know that I supply bolt in mounts for hilux / surf / 4 runner owners doing lexus conversions. We are using this conversion to design and manufacture mounts for the same vehicles that have had body lifts. The ute as pictured has another customers motor in as the second customer has a lifted Surf and needs the new design of mount. The Surf is a KZH185 I believe and we have made a custom sump to solve clearance issues around the diff. This motor will be removed to paint the engine bay.
The LN106R is getting a front sump. We have found that the rear sump soarer headers fit nicely when the bodies are lifted so will most likely use some of these for the job.
I am preparing a soarer motor for the job. I hve already done the tappet cover gaskets and resealed the half moons. The motor is getting a good cleaning which is shown.
In the future the ute will get air locking diffs and the tray cut down.
More photos as the job progresses
In the background is a RX7 which should be receiving a 1uz soon
