Here are some pictures of 4 bolt main conversion on Wayne's 2UZFE block. Its a work of art. It will house 4 11mm ARP Studs. More about 2UZFE Main conversion if you are interested of reading.
Many thanks David...coming from you, that is indeed a compliment! Starts and idles great..in fact, closed loop is pretty much running at 14.5-7 afr with no load and drops down to 14.1-13.9 as I start to roll into a little boost....as I say, when I run open loop, full boost, I am way rich around 10.1 so need to pull some fuel out of the map...which I will do once I get my other box. As it sits in the pics, I have by-passed the intecooler....spent today re-routing the piping from the turbo so it runs through the intercooler. Tomorrow, I will route the piping from the intercooler roundabout, through the BOV, MAF and into the Supercharger. We'll see what effect it has on the afr.
I experimented the other night by relocating the MAF before the turbo in the bed of the truck and it didn't work. Ran way rich all the time...not sure if it is because of the way the air acts on it back there with the draw-through instead of blow-through or the resistance of the 15 ft wiring harness screwed up the correct signal...(I used 14 gauge wire, so resistance should have been very low compared to the 22 gauge in the original harness. Either way, I have relocated it back to the original position in the pipe between the turbo and supercharger after the BOV. Will continue to play until I get it right.
Wayne
