3UZ-FE with stage 2 cams
Hello all, I made a mod this spring that went not as expected, with standard comp 10,5 i think, the stage 2 cams actually hade the max power to go down, in same dyno station max power with standar cams was 391hp, after mounting cams it was 385, the mid range power was a bit higher, but they hade to program for a lot of more fuel, and this togehter with their experience showed on that with more overlapping cams, the dynamic compression goes down, and have to be compensated to get benefit from them.
My earlier mods on motor is opened up in and out, headers, ported heads and all tuned in dynocenter with a unichip piggyback.
Also 100 hp gas, and that max power also went down, bouth mid range and top end from 495 to 475, irritating when I expected more hp with stage 2 cams....
So my winter project is big bore kit with higher compression ration, as high as possible with still a daily use car behavior.
(PS Im live in Sweden, so excuse my spelling and used words.....)
