3uz to Nissan patrol
Steffan
Hi guys not sure am in the right place here my first post newbie
Any way I am in the process of fitting an ls430 lump into my Nissan patrol that currently has a terrible 3.0 turbo diesel now i would like to keep the standard Nissan gearbox and i have sorced an adapter plate what I am struggling with is a flywheel that will take the Nissan clutch but have the lexus crank pcd the company I got the adapter plate from no longer make the flywheel I require although they do make one that would adapt a jz motor will that fit or am I barking up the wrong tree there
From your description of the 3UZ as a" lump" I'm guessing you come from the UK.
There are plenty of people who can make a flywheel specifically for your application.
I have a Nissan Patrol (4.2 Diesel) transmission behind my 1UZ and the flywheel is a work of art and cost around $600.00 Aussie 10 years ago. I made the adaptor for the transmission
Is the JZ flywheel the correct diameter and does it have the correct number of teeth with the lead in on the correct side and are the teeth the correct distance from the pinion.
A few issues to check. That'll keep you out of the Pub for a night Googling.
