AndreasMet
So I installed a JDM motor and kept the accompanying ECU and harness.
Motor did not start and I sent it to a local shop to see if they can fix it. if they want to charge a reasonable amount then fine. If they try to rob me then the motor comes back, I will put the old harness and old ecu on and hope that helps.
So I'm working plan (a) right now, plan (b) is old harness and old ecu.
Plan (c) is me doing any wiring work myself.
I have a copy of Nigel Wade's "How to Wire Up a 1uz-fe." Thnaks Nigel for making this available.
Can someone please provide some tips as to what types of tools I will need, and some other advice on how to do wiring projects. I'm in over my head on this, but with enough time and effort can probably figure it out.
Thanks in advance.
Thanks in advance.
