I did some research and a lot of honda engines have similar bores as the 1UZ, now we just have to check the cylinder spacing. I think it's very difficult to find retro-fit heads for the 1UZ. Anyone want to help with research? Bore is pretty important but the cylinder spacing is even
more!
I have done extensive modifications and work with Honda D and B series heads. Please let me know your needs. Very minor experience with K series, and almost 0 experience with H series due to their oddness and rarity.
D series is very common, it came in SOHC and DOHC in Japan. 75mm bore size. Almost all D series have interchangeability in block
B series is also common style head comes 81mm or 84mm Bore size. Mostly DOHC.
K series 86mm or 87mm bore size. These came in 2 very different set ups. 86mm variant is common, 87mm is not easy interchangeable with other K series engines as much as I know, most likely only came in automatic mission due to it's rarity.
H series 87mm bore size.I have never touched this engine due to it's incompatibility with all other Honda an lack of support.
I do not think there is any normal way to mount any of these head on 1UZ. For the most part Honda have free floating cylinders so the entire 4 cyl. sits in coolant. So the most part of the head is water jacket adaption, a couple oil paths, but the rest is reinforcement. A head adapter will have to be made to mate the 2 and combustion chamber shape will be completely deformed. D series heads have tons of space between valves, and between port and mating surface of head.
Keep in mind these are horizontally mounted FWD Inline 4. On D and B series engines the exhaust port is on the front of the car, intake on the back. On K series engines this was flipped over to have colder intake drawn through the front, and exhaust ports towards the back of the car.
That would mean the left bank exhaust would come out of intake on typical 1UZ set up with a D or B series engine head.
