31-81LE speed sensor problem
Solovey
Hi guys! Almost finished the swap my car. Yesterday, for the first time to leave the garage. Motor works well, and the box without changing gears. Box keeps first gear. Engine and gearbox from UZS 155 four-wheel drive
The connector contacts which must be SP2- SP2 + empty space. The connector has a pin 28P SPDM with him does not leave any signals. I tried to connect to SP2- SP2 + magnetic speed sensor which is located at the back of the box, gear changes have occurred. I found the wire out of the speedometer SP1, connect it to the SPDM nothing happened, also tried to connect it to SP2 +, again to no avail. I read somewhere that the signal has to go via the ABS. Help me please.
