2UZ Throttle body on 1UZ VVTi
!Zar!
I'm in the process of putting together a custom project and have come to a slight roadblock due to space restrictions.
Does anyone have insight as to how feasible it is to run a 2uz throttle body on a 1uz vvti? The 1UZ vvti throttle body is massively wide.
I know this could easily be done if I were to go standalone. That is a route I would not like to go.
Which 2uz throttle body. There are some options. The Stock ecu is quite sensitive to getting the correct signals for the DBW systems. I've played with 3uz stock ecus where a customer fitted a manual throttle body. I fitted a stock TB and used a KUN hilux pedal assembly to make it work correctly again.
The 2uz non vvti and 1uz vvti throttle bodies are identical. They are both cable actuated electric throttle bodies.
