turboandrew
Got the 2UZ-FE motor in this weekend. I made some custom mounts, so it uses the SC400 rubber isolators. Unfortunaetly the Tundra motor mounts will not work (not even close) and the SC400 mounts will not bolt up to the 2UZ block.
I state the engine "sort of" fits because the intake manifold is about 2" taller than the 1998+ 1UZvvti manifold, so I don't know if it will clear the hood. It's no big deal anyway, as I won't use that manifold.
I also had to enlarge about 1/2 of the upper oil pan holes to accomidate the M8 bolts
