2UZ-FE in place of a 1UZ-FE
dirtybrd
Being as they are basically the same motor is it a direct long block swap other than the motor mounts? Also, the 1UZ in the GS400 is rated at 300hp/310ft and the 2UZ is 271hp/315ft. Is this simply the tune in the ECU and if so would the tune in the GS wake up the 2UZ bringing its numbers up or would it not be worth the swap for the extra 7/10ltr?
