Hi all,
Looking at bit of tech info if possible. We are currently installing a 2URGSE into a supra. Will be a manual conversion as there isnt a TCU on the market yet of controlling the 8 speed box.
We are currently reseach control of the VVT-IE EDU with regards to external Controlling, and also the Direct Injection EDU's and 2 High pressure pump spill valve in order to retain the DI. On failing DI we will be running port injection.
Does anybody know the Stock 3UR tundra injector size?? we know the TRD injectors as part of the SC kit are 550cc but looking at them they dont sit as far into the ports as the stock items.
Was there ever a Manual 1ur/3ur manual gearbox? as a 10bolt Flywheel we make a start on the manual conversion before going custom
Marty
Marty
