I havint handed over the cash yet so its all good lol, thanks alot for that info guys because i would of been pisted! are you sure? it looks like a very clean motor to me but i really want the best bang for my buck so should i wait for a late model unit ? or not worry
any engine after a very nice engine shampoo will be as clean as this one.
the VVT-I one has bigger cam pulley covers to handle the space the VVT-I system takes.
So in your guys opinion what year and model engine should i look for ? i dont want vvti engine as it will require an even more expensive aftermarket ecu to control. And how do i tell them apart? dam you guys no your sh#t its awesome
If you want non VVTi then any engine before 1998 will be fine. The above engine is pre-98 non VVTi with front sump.... From my experience its from 1990-1994 Celsior...
there are 10:1 comp motors pushing an over-rated 250HP
and in late 1995-96 motors has 10.4:1 comp pushing 250-260HP (really)
Depending on what you plan to do with the engine. keeping it stock or N/A i'd gor for the 96 one. For forced induction I'd go with the other.
But, a 96 one with some bolt-ons and manual trans, in your lightweight 325 will sure give you a lot of fun, it won't be a Z06 vette but may give you a nice low-14 on the 1/4 mile.
Just spoke to the guy and he said he got the dats off the spark plug
leads lol. He also said most of the older engines are rear sumped and normally have the nasty log manifolds. The one in the pic has the better
flowing manifolds
Personally I like the 1990-1994 better because the timing belt is non-interferrence. This will give you alot of room for error if you are doing timing belt yourself. Its very forgiving. If it has rear sump the its a Soarer......
he has 7 engines coming in from japan in 2 weeks so ill have a look for a rear sump 1990-1995 because i like the sound of the non interference timing belt. Now im finally starting to get clued up haha, can you interchange the exhaust manifolds from different models ?
