A aliga New Member Oct 19, 2011 #1 ecus, motor, accessories, transmissions. will be junked in less than a week, post up with what you need. thanks.
cribbj "Supra" Moderator Staff member Oct 19, 2011 #2 Good opportunity for anyone with a front sump setup that needs a rear sump.
4 4U2QUIK Active Member Oct 19, 2011 #3 too bad you're on the left coast or i'd be all over the sump/pans
cribbj "Supra" Moderator Staff member Oct 19, 2011 #4 4U2QUIK said: too bad you're on the left coast or i'd be all over the sump/pans Click to expand... Brandon, you've been standing on your head too much
B BlackUZZ31 Member Oct 19, 2011 #5 What year are the cars? http://www.toyodiy.com/parts/p_U_1991_LEXUS_SC300~400_UZZ30L-ACPZKA_8202.4.html WIRE, ENGINE, NO.5 82124‑50072
B BlackUZZ31 Member Oct 20, 2011 #7 aliga said: both are from 95s. Click to expand... still interested in same part off a 95
EyesofThunder Member Oct 21, 2011 #11 Still have the ECU? aliga said: ecus, motor, accessories, transmissions. will be junked in less than a week, post up with what you need. thanks. Click to expand...
B BlackUZZ31 Member Oct 24, 2011 #12 gloverman said: Is it the front crank sensor Loom? Click to expand... yeah that would be it!
