cyberdiamond
1UZFE VVTi engine/trans harness/loom factory ECU, 5 speed Auto MAF etc
Basically I can supply complete front cut without the engine (or I guess I could sell with it and I will get another one?) including all the body looms and anything else you might want or need as I have kept it all. I have had the engine running and it ran well.
The ecu does not have the security inbuilt/enabled so you won't need to worry about ignition transponders, keys etc to get this running.
Although I do have the original keys and ignition barrel, dash etc if you want it.
I have spoken to companies that can wire this so it is plug and play for $650 - $950. Just send the loom out and get it back turn key for your conversion if you can't or don't want to do it yourself.
Will supply the factory manual that I ordered from Toyota for this as well.
I also have a spare ecu (identical numbers, so also without security) and the plugs with a couple of feet of loom still attached.
I am selling this as I decided stand alone was better (but much more expensive) for my end goal and horsepower I will be running.
