Needing some info on the mounting differences between the 1UZ-FE and 2UZ-FE power steering pump. I would prefer to swamp out the 2UZ-FE pump with the 1UZ-FE pump. As the reservoir is integrated into the pump. Does anyone know if the mount points/brackets are different. If so, is there a way to make the 1UZ-FE pump work on the 2UZ-FE motor?
Thanks in advance!
Thanks in advance!
