1UZFE Sump Flange AutoCAD drawing files
Does anyone have a front sump, 1UZ steel sump pan flange drawing?
I used the original sump to make a custom one for my Surf. Have found that it weeps slightly and the clearance isn't the best.
So want to start from scratch. Have searched but can only find the upper sump drawing.
Cheers.
You will find your answer in the Fabrication Section.
Thats the aluminum section, or upper pan. I need the lower pan, or steel section. Thats the one I haven't been able to find.
Cheers for the reply. Anyone able to move this thread?
it was £25, i had mine done in bradford but there will be loads of laser cutters closer to you than that, one thing i noticed is that one of the bolt holes is slightly out, i just drilled it 2mm bigger and the bolt went in ok.i messed a few up but what i had left over are on ebay.
Not a problem, the least I can do, plus I'm planning to fab my own sump as the UZ's is huge compared to the previous engine I was going to use. Would love to go dry.
Anyway I like to give something back!
