HI,
Have been looking for the last two weeks for a solution for this problem, Have a 1uzfe from a sc400 that i've put into a nissan ute. Am running completely stock ect and loom, just powered up the wires needed.
The motor fires up, then dies within a sec of running. For that second it runs very rich, maybe just starting on the cold start injector, The injectors are getting a good 2-3 pulses then stop. Any ideas? Have power and signals to everything i can trace off the wiring diagram. Has good spark that keeps sparks aslong as its turning over.
Has a fuel pump run off the power from the key.
Have had this running but now when i want to drive it out of the garage it does this.
thanks for any help
Hayden
thanks for any help
Hayden
