Oops - not v2, its 3.3... wonder if the files are compatible... anyway, uses .dat extention.
Dont suppose you have engine dimensions? Phil Bradshaw's notes say they are approx 700sq, but I need more accurate measurements than that to see if a 1UZ will fit into the new racecar without major chassis mods.
If anyone can help, I need from harmonic balancer to rear of block (if balancer is furthest point of long block... wheres the dizzy?), widest points of rocker covers, and height from sump to the point where the engine is 375mm wide (so I can see if the rear arms will clear the block).
