well im gaza from newzealand...........im in the 3rd month of my sumdinith?????build.
it is a 1UZFE powerd s13(factory sr20de) with a 180sx front convertion.iv made and fabbd up the engine mounts/brackets,runing a31 xmember-swaybar.s13 rack with r31 powersteering feed and return to pump.made a solid spacer to make up the diff in the lenth between the steering rack nuckle & conection to wheel.also made a custom stem pipe part to go around steering rack.have removed a/c and found a shoter belt (volvo-renault) that runs all pumps needed.
NOW....iv got the whole loom + the plug off auto box.
im needing to know what wires do what to power up ecu and nessasery engine parts.
photos of powersteer vacums to compair.
'' '' '' '' vacum to run break booster.
'' '' '' '' '' advice on running a fork and thrust bearing or the hydrlic? vertion
'' '' '' '' i al so have cut oil lines that went to sumthing????they close to pump.was like it from japan.
well that will do for now hope sum1 can help out with my build cheerz![Confused :confused: :confused:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
