Hmm interesting thing to measure up.
I do not have the engine at hand right now, Will try and awnser what you asked,
just to be sure,
1)You want the distance from Bellhousing face to the center of the rear most boltholes in the engine mounts?
2)the width of the engine inbetween the mount faces? as in measured through the engine? hmmm need to make a measuring jig to do that, but nice experiment to get right. I asume you also need the angle of the faces towards the vertical center line of the engine? (ie single and combined angle of the 2)
can you confirm these two? I'll measure them up asap.
would you by any chance be putting this into CAD?
Grtz Thomas
Hey Mike,
I think I have them covvered,
the distance from flange to top mountening hole is 25.5cm
the distance from sump bottom to top mountening hole 29cm
the distance through the engine from top hole to top hole is a surprizingly low 39cm (making a caliper was a good idea!)
I've also updated the drawings with these measurements for ease you could print them and put them on the wall of the workshop
good luck with the project,
ps do I read you're name as in "Mili - SAKER - acing" as in the south african Saker LMP, or is it just a nick and do you stick to supra's?
