Hi all im a new member and ive decided to drop a 1uzfe into my 91 hilux 2wd and im after any bits of usefull information plz
basically i have a 1uzfe front sump with a cut loom and a 22r hilux gearbox im guna buy adaptor plate and mounting kit for starters clutch etc and a radiator and if a buy a walbro intank fuel pump will this work fine and will i need a adjustable fuel pressure regulator? im planing on running a link.
also i dont have power steering what should i do bout the pump on the motor diasble it sumhow because if i pull it off looks like the belt mite run in a good pattern if you know what i mean.
and tips and usefull info for me would be greatly appreciated
cheers lance
cheers lance
