the biggest pain with putting toyota motors into nissans is the price to get factory dash to work
to get all factory dash on the 300zx to work perfect with the 1uz it cost the customer
nearly the same amount as what to wire up the motor
was about 500 bucks in signal correction boxes for speedo and tachothen uneed to fit the 300zx oil and temp senders
but wiring would have been easiest part cause i have hand drawn diagrams of the body plugs on the 300zx
nissan wiring is much easier than toyota
Yep this was one majour pain in the arse conversion. But shes up and running.
Car is about 40kg lighter in the front and noticeably sits up on the suspension. Looks like I need a set of lowered springs for the front now.
Sump:- Started with a rear sump, milled the thing totally flat start from the front and worked all the way to the back. some custom made aluminium inserts bit of aluminium welding, made use of the standard steel pan but mounted front to back abra cadabra and one new sump. Oil pickup was lengthened 100mm. Not so hard really
Engine mounts:- modified 1UZ hangers used with quite a bit of custom ali work to bolt on LS1 rubber mounts.
Engine fits in realy neat into the engine bay, more room left around the engine that the old cast iron block v6. I made a set of custom 4 into 1's 1 5/8" primary pipes into 3" collectors with a grouping cone inside the collector. Pipes are HPC coated.
Engine is stock, mild port work on stock heads with 80lb springs. Everything inside the engine was polished, corners removed, radiused etc. 320cc injectors fitted, wolf V500, full sequential injection and ignition running toyota COP.
Auto was rebuilt with a very mild shift kit added. I designed my own tiptronic controller for the auto with a few smarts in the software to make work it shift and behave as an auto should but with manual control when I want to use it. Drives great. These things stick to the road like a go cart. It appears like there aren't too many V8 300ZX's in Melb
Challenges:- Yep the wiring was a pain in the butt, the air/con and power steering did give me greif and did take many weeks to sort out but thats half the fun of doing this short of conversion. Now I'm gonna drive it for a few months get rid of all the squeaks and rattles before chasing some a little more power. Many thanks to Robbie McQeen at Wolf EMS giving me a few pointers (lots of help) to help to get the thing running. Man this guy knows hes stuff. The Wolf V500 is one powerful ECU.
Picture added
Knife edged crank, full balance, H beam rods, arp2000 rod bolts, 8.5:1 Ross pistons (ex cribbj), block fully deburred inside and out to remove all casting flashes, heads ported (too many hours went into them) flow tested 3 times to get the best port shape and flow. Inch & 5/8 4 into 1 to 2 x 2.25" system. Std valves and combustion chambers. Kelford blower cams and springs. ARP head bolts. Bullet intake again spent hours porting it to make it fit right. M122 ported on intake side. Makes a shade over 1 bar. Hidden 150 shot nos system under manifold (never used), MSD Dis4 coils with msd cdi, msd 8.8mm spiral leads. Remote engine oil cooler, water meth, Auto A431, shift kit, remote cooler. Line lock but not needed. mt pockets. Fun to drive as a cruiser.Performance just had an upgrade.
What other mods aside form the supercharger are there?
Can you be a little more specific on what you used to mount the engine?1UZFE in a 300ZX Z32 is up and running on the road
Modified (cut and welded) the standard 1UZ engine mount supports to take LS1 rubber mounts. LS1 mounts use a 13mm thread, 300's use a 10mm thread. Position your engine and you'll work out what needs to be done.Can you be a little more specific on what you used to mount the engine?
