dulobast25
I have a cast steel flywheel and 1200 lb pressure plate for sale. Unit fits 1uz, 2uz, and 3uz engines. Requires no modification. Included is low mileage pressure plate capable of holding 260 ft lbs of torque with stock clutch. This setup uses the stock 1uz flexplate hardware and bolts and the pressure plate uses stock bolts from 7m supra,v6 truck,or 3sgte.
Price is $280.
This will allow you to use your own clutch and bearing options but you have the hard work done for you.
Should you want to include add an upgraded clutch disc:
The setup can hold 310 ft lbs of torgue with 6 pluck clutch, which is avail for and additional $185 or you can use a 4 puck clutch also for $185 which will up the ft lb rating to just under 400 ft lbs.
Let me know. I just have this one setup. It is ready to ship.
Price is $280.
