1uzfe and r154 - Which flywheel?
200sx-v8
As topic says. What flywheel can I use to make this conversion work?
I assume the starter will be in it original position, so the ring-gear would have to be the same as original.
The starter on the 3sgte engages from the opposite side, hence the need to grind a lead in onto the teeth on the opposite side.
Clutch selection is not a problem as any of the W series toyota boxs and the 3sgte also R series 4x4 eg r151, r150 are all ok.
And of course aftermarket versions of these if a higher clamping load was required.
i am jumping in late here, but can you explain a little more about the lead in mods to the flywheel? please....
