Here is a lot of the detail that I copied in from another forum. It should help give a head start to anyone attempting this project.
Currently, I have put over 2000 miles on my setup including hard launches at the track and long drives around town. It is great and was worth every penny.
I'm not sure of the rules on posting other sites on here, but if anyone is interested in reading through the original posting, here is the link: http://forums.nicoclub.com/zerothread?id=271939
Moderators, if this is a problem, I will gladly remove it.
If there are questions, feel free to email me at [email protected]
Thanks
Watty
Happy reading:
Here is my introduction post for the new project. The KA supercharger kit is sold so I can finally put some money into this. We are doing an N/A 1UZFE mated to the KA transmission. Eventually I want to upgrade this to a Z32 tranny, but I have a couple of these laying around. The motor mounts will be finished by tomorrow evening and then the wiring begins. The goal is to have this running by NOPI Nationals. I am using a Megasquirt I 3.0 PCB to control the whole thing. I am going to attempt to use the dual dizzys and trick the megasquirt into a "wasted spark" setup switching between the separate coils. Anyway, I just wanted to give a quick blurb and some pictures. There will be more to come.
Watty
![P7170222.jpg P7170222.jpg](https://www.lextreme.com/forums/data/attachments/14/14699-dc585c53b0df0420c453d554715b1ecc.jpg?hash=3FhcU7DfBC)
![P7170220.jpg P7170220.jpg](https://www.lextreme.com/forums/data/attachments/14/14700-c5b0c568dbf3a6305ca45058fae6bfea.jpg?hash=xbDFaNvzpj)
![P7170212.jpg P7170212.jpg](https://www.lextreme.com/forums/data/attachments/14/14701-7af25466e45223eca4107153f1bcea70.jpg?hash=evJUZuRSI-)
![P8010010.jpg P8010010.jpg](https://www.lextreme.com/forums/data/attachments/14/14702-761e487cb47bcc0840860c31d1ebfd22.jpg?hash=dh5IfLR7zA)
![P8010013.jpg P8010013.jpg](https://www.lextreme.com/forums/data/attachments/14/14703-47397b0c520c1f58ead6bd8652d8cdbc.jpg?hash=Rzl7DFIMH1)
![P8010017.jpg P8010017.jpg](https://www.lextreme.com/forums/data/attachments/14/14704-1b4684a046514fb9af416af64dbeee28.jpg?hash=G0aEoEZRT7)
![P8010018.jpg P8010018.jpg](https://www.lextreme.com/forums/data/attachments/14/14705-04d0de8d81ca26e0e5b03dc1f105b831.jpg?hash=BNDejYHKJu)
Hey guys, sorry for the late response. I have quite literally been killing myself in the garage for the last two weeks trying to get this thing in the car and running for NOPI. It sadly didn't make it. I got down to about an hour and a half before we were supposed to leave on Friday for Atlanta and had to call it quits. I was sick and running on 3 hours of sleep. I will be putting up some more pics and information this week now that I'm not rushing anymore to get it done by a certain date.
Here is a teaser pic:
![P9140082.jpg P9140082.jpg](https://www.lextreme.com/forums/data/attachments/14/14706-2913c07985cc0e1c4b82363fe962b43f.jpg?hash=KRPAeYXMDh)
![P9140081.jpg P9140081.jpg](https://www.lextreme.com/forums/data/attachments/14/14707-7b5ad308ea0fcd47fa7e56a5eecd9472.jpg?hash=e1rTCOoPzU)
![P9140080.jpg P9140080.jpg](https://www.lextreme.com/forums/data/attachments/14/14708-66ce5e2a32e50181d73e71730e81c65e.jpg?hash=Zs5eKjLlAY)
There are more of the install and mounts. I will get around to putting all of this together. Now I've got to get the Megasquirt to play nice with everything else. Also, the engine bay has not been cleaned up and the throttle body is going to go through either a major shave down or replacement. We'll see.
I should see him some time in the next week. I'll tell him you say hi.
Thanks for the interest,
Watty
IT'S ALIVE!!!!!! It is running and moved under its own power last night. Granted, I only moved it back and forth in the garage. I have a heater line hose that has a hole in it. So that is next on the list. I have to adjust the timing and then it's time for street tuning. YAY!!!!!! The clutch has ended up very SHORT. It's not undrivable, but I should have quick reaction times at the track. :biggrin
I know I haven't posted up more details yet, but I've been more concerned with getting it running. It feels as though a huge weight has been lifted off of me. Time for a relaxing night of beer to clear my head. It is bad when you have dreams about fuel maps and enrichment tables.
More to come,
Watty
Here is an email I sent yesterday. It should help with most things.
"Hello,
I am more than happy to help you out with this. The adapter plate is actually pretty simple. It is a 3/8" thick piece of mild steel. I happened to use a plasma cutter, but any way you can get it cut will work. I used thick paper to make a template by placing the flywheel on it and cutting an oversized hole. Then I mounted the flywheel and made a rubbing of the holes in the block. Next we drilled out those holes and the center section from the plate. You will need to countersink the holes for the bolts to the block. After that is done, you bolt the plate to the block. You will have to grind the starter bolts a little to make clearance for the plate to be flush.
Next, you need to make a bushing that is the size of the inner bore of the crank and the outer bore of a factory Nissan pilot bushing. We turned down a piece of stainless rod that was laying around. After that is tapped into place, you can mount the clutch and flywheel.
The flywheel does need to have the holes milled outwards radially about 10 to 15mm. I don't remember off the top of my head the exact measurements.
Once the clutch and flywheel are mounted, you can slide the tranny into position. This is not the easiest thing to do the first time. Once it all lines up, you just use something to go through the holes in the tranny and make marks. We used a drill bit with some tape on it so it fit the hole centered. Drill and tap these marks. You can use automotive studs or cut up a piece of all-thread to make your own. Now your transmission and motor can be mounted together.
As for motor mounts, I have some pictures that will explain way more than I can in words, but they are VERY easy to make. And if you want to move the motor back, I think you can bolt it straight to the crossmember. Not 100% on that though.
That should be a start and something to think about. Also, you will have to remake part of one the headers. It depends on whether or not your car is left or right hand drive. The fabrication isn't that bad, but you will need access to a few tools that can be hard to come by like a lathe and mill.
Thanks,
Watty"
As far as the radiator goes, I bought a 3" aluminum from a guy on here, but it was about an inch too tall. I'm not sure if there is a difference between the s14 and s14a. Either that or I got an s13 version.
Watty
Thanks
Watty
Happy reading:
Watty
bball212000 said:watty i cannot wait to see this s14 driving around town, tell keith i said hey if you see him
Watty
More to come,
Watty
"Hello,
Thanks,
Watty"
Watty
