No probe I doubt it's fuel press reg as it would not fail at 4000 rpm
and I've never seen one fail in over 100 1uzs
if engine doesn't have a miss all way up to 4000 then doubt it's injectors
It seems to miss all way through the rev range now with a knock...
Has timing belt been done
Timing belt was done 10,000kms before the car was in an accident. The Timing belt was done at 165,000kms and the car had 175,000kms on it when i got there is a verication sticker on it when it was done on the distributor cover.
is the tacho set for 4 cyl
Tacho is not connected just yet...I might get you to do that as well as my fuel gauge 4000 rpm was estimate, but really its not making power at all now. Idles well
I have aces ignitors to try anyway incase u got wrong ones
Yep could well be the ignitors however I pulled the engine out of a running SC400.
anyway see u on tues
