Finally got everything working properly. The car still needs more tuning. Still running a little rich on those Rx-7 injectors. The turbine housing is from Precision Turbo .82 A/R with the stand bearing GT40. From Vacuum (-18 psi) to 0 psi is about 1,700 to 1,800 rpm and it reaches 9 psi at around 2,500-2,700 rpm. The boost comes on very fast. My car has been sitting for a while now and the battery is not fully charged and I am working on that. (Split Sec requires the engine to be off when loading programs. On and off engine is not good for my weak battery right now.)
I plan to run 15 psi and I would not be surprised to reach that in mid or late 3k range. It will be very interesting to find out the potential of this motor.
