M muzzytt New Member Jan 11, 2016 #1 I'm looking for a front sump someone has one from a 1uz vvti . Will this fit the early rear sump uz? Im hearing bolts might be different size? Cheers Muz
JustenGT8 New Member Jan 11, 2016 #2 Fits fine. A couple of the studs are a larger diameter on the VVTi block but shouldn't effect you going the other way.
M muzzytt New Member Jan 11, 2016 #3 Cheers mate. The other guy wants my front sump he will fit it to the older uz i think .
G gtech2 New Member Jan 29, 2016 #4 Do you know if there are any small difference in actual size or height? Wy did they change the sump eventually? I also saw that the engine mount parts are different for a ls400/celsior non vvti/vvti Thanks.
