Hi all,
I'm currently doing an engine swap and I've run into an issue that I can't figure out. This engine worked fine when I pulled it out of the a 400
My engine idles at 2000rpm +/- a 100rpm. Its a constant smooth idle, It advances the timing to around 35 degrees straight away and keeps it high, won't go lower, my stock 400 keeps it at 7.5 degrees at idle.
It starts up easy, runs for a second, pauses for a moment as if the power was cut then carries on running.
The things i have checked:
Vacuum leaks - none.
Fuel pump keeps fuel pressure up at 3.5 bar.
ECU works fine in my 400.
Checked/swapped MAF - no difference.
Checked/swapped crank sensor - no difference.
Throttle body isn't excessively open when running.
Checked timing belt - cams line up to TDC when cranks at 0
Stock transmission - runs the same when trans is or isn't plugged in, rpm does come down in gear but its still 1300rpm.
Coolant temp sensor works fine - idle comes down slowly with coolant in but only to 1600. Disconnecting it causes a rough idle and difficulty starting.
All four O2 sensors are connected and working.
Oil pressure is good.
Immobilizer works fine with the stock key.
Engine loom is uncut - only bits ive crimped is to plugs E11 and E15 with power wires connected on that massive fourth plug from the engine loom
Its something wiring or sensor related and i have no idea where else to check. Any help would be appreciated.
