I dont know if this bit of info will help you Justin, but I do know that the later VVTI MLS Factory Headgaskets fit and work on the earlier blocks and heads, so I dont see why the later heads would not fit the early block....
I sold a complete set of heads (heads, cams, pullies, nuts and bolts along with valve cover) for $300 usd but they dont happen that often. I can keep my eyes open if oppertunity arise.
I paid $550 AUD for heads, inlet manifold, billet fuel rails etc etc. I won't be bothering with the VVTi, at least not until as easy solution presents itself.
The oil feed is one issue. The other is my Autronic could only run the VVti with a simple PWM table so not really 'i'. With a smaller capacity engine i would have a crack but the mid range is so fat on my current setup i'm more than happy. I'm really just after the better port angles and increased flow the VVTi heads provide.
A little ways off yet so may change my mind.... like i said, if a simple solution presents itself.
BTW my mates n/a VVTi with SM4 (i run SM2) just cranked out 208rwkw with only exhaust mods!! Hell impressive for virtually a stock UZ.....the VVTi heads must be a big improvement.
Bad bad bad news....looks like the oil galleries from VVti block to head are totally different to non VVTi block so the VVti heads are looking good as a swap.
Still to be 100% confirmed but RMS had a look at the heads and spotted the different gallery positions straight away so likely to be a deal breaker
