Hi all, have fitted a vvti 1uz into my comp 4x4 which has no heater so i need to bypass the hoses for it, am i better blocking them both off or connecting them together? have got them connected together at the minute but seem to be struggling to bleed cooling system. (running davies craig elec water pump with radiator mounted in rear)
Also have very low idle at the minute, do the iacv play up on the vvti motors?
Can't seem to get techstream to connect so can't pull any fault codes.
if that is just how it idles, can it be upped at all?
