1uz vvt onto 350z 6speed
ecKo.
have a 350z 6speed to going on to a 1uzfe vvti
any know where i could find a yoke for it ive had no luck anywhere
need it to make up a custom drive shaft
cheers
Stag auto dismantlers in Auckland (09 828 8750) have wreaked a manual 350Z. They have a driveshaft which is a carbon fibre unit. Yoke and first part of shaft are steel though. Give them a call - Maybe you could post some photos so people understand what you are doing. The box looks really good on the back of the V8. cheers Kelvin
this is why you need to be very clear....
if the car is a 350z and the transmission you plan on useing is from a 350z then you dont need to do anything with the driveshaft to swap the motor. the transmission will be in the correct place or should be rather.
Now if you plan on useing one of the toyota transmissions in a 350z youll need a yoke for that transmission..
your first post isnt very clear what exaclty you need hence me asking.
The man is building a hilux with a lexus v8 and using a 350Z 6 speed manual box behind it. I had some photos come through on my email and it looks very cool. Cheers
