Ok, from what i've read and seen, the 1uz has allot more meat between the sleeves. So wouldn't the best of both worlds be a 98+ VVTi 1UZ with a set of 3UZ Heads Ported for a big forged induction setup?
Also what does the oiling system look like for the 1UZ bottom vs. the 3uz. The 3UZ looks to be like it was designed from the 1U straight for a dry sumped setup IE In the gt500 cars. Is the oiling system on the bottom end the same on 98+ 1uz?
From what I can see, the 3uz Doesn't look like it has advtages for big forced induction and looks to me like it needs to be resleeved and a new set of pistons due to the iron coating? Also, I'd probably block off the VVTi because I have no need for it, so would it be more beneficial to just run a set of 1uz heads or is there that big of a difference to work with the 3uz setup. I hear the valves are bigger and I'm looking to rev to 10k and boost with something in the ball park of a 91-101mm.
Other than that the 1u setup looks pretty bullett proof at 4.0L, and they're readily available.
Am I correct so far or incorrect, someone let me know.
 Ls1s can make upwards of 2000hp why can't 1u? With enough boost you can do it easily, yes big CU big blocks have 2 bolt mains and can live just fine I agree, but, I just don't see what's wrong with the 1U + 3U or ported 1U Heads? That seems to be like the ticket. Why spend 20k on a motor, when you can spend 5 and hold 15-1800hp which it appears, the 1U can do very easily, now the quesiton is the head,s I know the 2u heads are more boost friendly, but I mean the 3U heads look to be the ticket, so my question is, 3u heads, 1u block, best of both worlds?
