1UZ UCF20 runs horribly rich
smokeymx5
Hi all, I created an account just to try and solve this problem on my project car swap. I'd really like your thoughts on the issue, but I guess even if noone has any ideas it helps my head to write it all in one place.
I've had this issue for probably 2-3 years, and since I'm finishing up everything else and trying to get it roadworthy I really need to sort this, but I'm just struggling to work out what to do.
Basically, I have a later non-vvti 1UZ swapped into a miata. TL;DR, it runs so rich and pours smoke out of the exhaust. Long version of the problem is this:
ECU power on, key on, gives code error 31 for MAF.
Engine turned on, it starts perfectly and settles into a good idle. 14.7afr, spot on. Then... after about 5 seconds, the afr drops slowly. After about 10 seconds, the afr is on the minimum reading of 10afr, and smoke starts to come out the exhaust. The smell of fuel is horrendous. However, it runs and idles just fine. Revs up nicely. Seems to have decent power, I dont think its in limp. When codes are checked after engine on, I get the following:
21- o2 sensor (AEM output wired into ECU, 0v-1v)
27- sub o2 sensor (it doesnt have one)
28- o2 sensor (AEM output wired into ECU, 0v-1v)
29- sub o2 sensor (it doesnt have one)
31- AFM error
71- EGR (deleted, blanked)
78- fuel pump (Uses aftermarket bosch 044 wired to a panel switch)
It is running stock ECU and wiring harness it came with. Manualised auto box. Plastic maf. AEM wideband with narrowband 0-1v output into stock ecu.
Okay so lets list the diagnostics I've done so far:
Coolant temp sensor test at sensor, resistance within spec for ambient temps.
Opened ECU, checked for faulty caps. Seems fine, no evidence of leaks or damage.
I was using thin oil, swapped it for thicker stuff in case it was leaking past stem seals or something.
Wired in o2 sensors. I was originally using no o2 sensors, so wired in the AEM gauge narrowband output of 0-1v to the two main o2 sensor wires to the ECU.
Replaced MAF
Replaced MAF plug (wire was split)
Checked maf wiring. THA and E2 have correct resistance across them, 2.6kohm. E2, THA, VG all have continuity to ECU. I cant figure out what pin B and E2G connect to? I cant get continuity of B to anything. E2G has a connection to ground with negligible resistance. E2 has connection to ground with negligble resistance. THA has 5v.
When MAF is disconnected, there is no change at all.
And no, I havent put any cleaning solution through the MAF!
To me this seems to point to the MAF. The 31 code, unplugging and it does nothing... OR injectors stuck open. OR the classic faulty ECU. In that order.
So next I think to diagnose on the MAF is finding continuity between B and something. I dont have a frequency thingy in order to test the output frequency, I assume is the VG wire. I might have to invest in one. I might even buy a THIRD MAF just to make sure. But I suspect wiring is the culprit.
Lambda sensors - its just the narrowband output from AEM wideband running stright to OXL1 and OXR1 together. Voltage has been verified to be correct. Is it really as easy as this? I assume the errors are for things like the heater circuit having an open reading as the correct sensor is not present?
As for the injectors - when I disconnect one or two the smoking is reduced and the afr rises to about 10.2, but I dont really think im proving anything here because it must be all of them together to be smoking this bad. It doesnt sound like its just one cylinder, it sounds pretty smooth for its condition, no misfires. If they were stuck open, why would the car run so well in the first 5 seconds and drop down the afr range so smoothly? The same for fuel pressure. I had suspected the pump I was using was too good and is overwhelming the regulator and causing rail overpressure, but if this was the case then it would be rich right from the engine start.
Really any thoughts are appreciated. Especially on MAF and lambda sensor error fixing. I'm fairly confident the error is somewhere in the wiring. If I can get rid of these main codes I might be able to solve the issue. I've probably spent upwards of 100 hours just trying to figure out why its smoking so much. So sorry if this is a bit rambly, I think I'm losing my mind.
I would be sorting the list of codes , a couple of which are wiring faults. Search CartuneNZ on YouTube. I may have helped out there otherwise I sell instructions.
I'll check out the channel for more info. I've seen a few vids but there is so much info on there!
Yeah thats what I'm working down, but I'm a bit stuck on my MAF diagnosis as to where pin 1 and 5 connect to in the ECU for a continuity test. I think I'm getting confused over earlier wiring pinouts for a 92 as opposed to the 96. Which ties in to:
Just a minor point: Is the AFM the correct one for the ECU you have?
I got given the MAF, harness and ECU along with the engine and trans when I bought it. But since you mention it I shall check. My ECU is 89661-50251, which I believe is UCF20, the later non-vvti, and the later plastic MAF. So I think its the correct one.
This makes me think about differences in early and old MAF and MAF wiring... I need to go back and double check what I'm testing is correct against the correct year as opposed to old pinouts... I know its going to be something really simple such as that lol. Thanks guys, I'll have a look at it tonight
As for the lambda sensors, is it acceptable to just tie the same narrowband output to both the OXL1 and OXR1? Or should I go for all four, front and back? Not sure why its still giving front sensor errors, I guess its not seeing the heater resistance?
So I watched some more of that channel and found something interesting. I have a further theory regarding the AFM, but I am struggling to find/read diagrams to prove or disprove it. The white plug that is on the engine harness that doesnt plug into the ECU, (Chassis plug maybe?) could be a culprit. As shown in this video at around the 2:00min mark:
I dont have that many wires going into my white plug. I have two 12v leading in (one is starter), and I think from memory I have a ground running in. He says one of his wires is power to the afm. Perhaps my AFM needs a 12v from somewhere in this plug? This would explain why the air temp sensor works (no codes thrown) because its a seperate circuit... And would make sense why I cant find continuity from the AFM to something to supply it power other than the 5v to the IAT sensor.
Anyway, I suspect if I can find a pinout for that plug, I might be able to fix a possible power to MAF problem.
Funny enough I have the pinout to that plug in my wiring instructions.
I'd absolutely love that pinout if you have it please!! How much do you sell your instructions for? Or even just that pinout, because I have the rest.
Also, I managed to fix the smoke issue. Whilst I didnt have a pinout, I did have my multimeter so I started probing. I probed a red/black wire in between the large ignition and starter wires I have on that plug. Turns out it leads to B red/black wire on the MAF. Maybe leads to more things too. I put 12v to it and hey presto, maf code dissapeared. Turned the car on and no more smoke on idle! Idled for about 20 seconds at 12~ish afr before spluttering and cutting out because I ran out of fuel in the tank. Doh. But that is that code and the majority of the issue fixed... Now onto the o2 sensor codes...
It makes me wonder what else is on that pinout that I need. I think there must be power to igniters on there, I had to cut into the ignitor wire to give it power a year ago because I couldnt figure out what was supplying it! In the video it says power to injectors but it seems to be happy enough without it so not sure on that one.
Then my roof started leaking so I couldnt play with wires anymore until I've fixed that, sigh.
Still having issues with this, turns out it wasn't running out of fuel, it just runs super lean and wants to die unless I rev it a bit. Then it injects fuel as normal which rules out a lot of stuff. Any return to idle will eventually lean out and cause a stall after about 10 seconds. I guess this is because the lambda sensor codes mean whatever signal I'm putting in to the ECU isn't being used for closed loop?
So, trying to find a way to get rid of error 21 and 28 whilst only having the single wideband with gauge and narrowband simulator... Thinking about wiring in an O2 sensor or two to the stock ECU purely for the heater circuit. Although a better solution might be to put a resistor across them to simulate one, if I can find the correct resistance.
So... @gloverman ... How much for these wiring instructions? Either that or I go custom ecu but I'd really rather save the money for now.
edit: also starting to suspect all the throttle/idle junk is not set correctly or stuck. Makes me want to set the thing on fire to be honest. So gotta go down that route of checking and adjusting, if I can find documentation on how to set everything up on the throttle body from scratch.
My wiring instructions for ucf20 non vvti are $175nzd at present. They also include 20 minutes of my time for personalized questions. Email is [email protected]
Sounds reasonable. I think if I had a better guide than the 1uz doc by Nigel Wade and various forums I could fix a lot of issues much quicker. Or if I went custom but really don't need that at the moment.
I'll shoot you an email
Maybe this will help you?
With that many errors, a faulty ECU is suspect.
Caps may look fine but be dead.
Literally every single early SC400/LS400/Soarer ECU is 'dead' in different ways now due to age.
Best to recap, or find a recapped one ASAP in my opinion.
Thanks
Yeah I opened it and had a look a while ago, didn't see anything obvious but that doesn't rule out something just failing internally. Didn't go for a recapped ECU because I think I'll just get an aftermarket ECU at this rate, but don't have the money just yet. Also the problem is I know why it's throwing the errors (no O2 heaters, no EGR etc) so I can't blame it that quickly.
I have a bunch of stuff ready to put on the next time I work on it, hopefully today:
-Two lambda sensors to wire the heaters in so the ECU stops faulting and hopefully uses the wideband signal to correct the fuelling.
-Going to redo the vac lines, I think there is a better way of having them plumbed in. I think there may be a stealthy vac leak due to the current plumbing.
But yeah you're right, I need to just take the L and get an ECU when I can afford it.
Probably is best to get an aftermarket ECU rather than spending $400 on a recapped ECU which is already 20-30 years old as you mentioned, yes.
Issue is the price, plus the price to tune that new aftermarket ECU. You're looking at $2000-$3000 or so I believe.
Will you have your car another 20 years? If so, maybe invest in an aftermarket ECU, otherwise find a reputable recapper.
The thing with the ECU's, it is not just the capacitors that can leak and bulge, you also have the little drivers and resistors and all that which go bad, along with the traces/tracks and so on.
What else I've noticed is many persons seemingly do not recap the ECU's correctly, and either do not wash the board, wash it wrong, or use wrong capacitors, usually wrong voltage and not low ESR!
It is very easy to repair tracks with a bit of wire, or even a track pen (you can draw tracks!).
You must beware recappers as many will claim yours was broken during the recap, when in fact it was perfectly restored. They will offer you a crappy banged up ECU as a replacement, and you won't see yours ever again.
They will then sell your recapped ECU for $500.
Sad but true.
Anyhow, that said, MAF error and idle or fueling issues is usually the ECU on the way out (or spark related)- or someone has cleaned the Karman Vortex MAF with MAF cleaner and destroyed it. It's about $500 brand new. You can unplug MAF and car will run a little rough, but will have more horsepower when flooring it. You will also go through a lot of fuel.
I just read with MAF disconnected you have no change. I would suspect dead coil/rotor/spark plugs/ignitor/throttle sensor, or faulty ECU. My bet would be on something ignition related at this stage.
When I was semi-new to Soarers (sc400), I bought one which was running on only 5 and a half cylinders - still had lots of power. Nothing happened when MAF unplugged so I fiddled with TPS and screwed the position up on that too it turned out. Thought everything was fine because I read reviews online that said the Soarer is simply a slug til 3k rpm ( which it isn't!!!). Replaced spark plugs and wires, and it had double that power... Was amazing.
Thought it was the ECU but it wasn't - so check sparks!
Replace with the cheapest COPPER plugs you can find - don't worry about platinum or iridium. BKR6ES-11 (gapped to 0.44mm) are the ones you want for the Soarer V8. (uzz30/31/32). I use them in my Soarer V8's.
All race cars use copper plugs. They last 30k miles on average. Takes 20 minutes to change 8 of them. $2 each.
Why buy plats for $20 each? They last longer, but perform worse. This is fact.
The plats and irids last 100k miles or so. But are over 4x more expensive, and give lesser performance - so forget that.
Also beware that Denso holes are smaller than USA Lexus holes on rotors and distributors - Denso Japan has locator rings inside the holes, whilst Lexus does not. There is a difference between US Lexus SC400 parts and Toyota Soarer ignition parts of same years. Bosch brand only stock large hole items for USA vehicles but market them as for a Toyota Soarer JDM.
Peace.
Sad but true.
Anyhow, that said, MAF error and idle issues is usually the ECU on the way out - or someone has cleaned the Karman Vortex Maf with maf cleaner and destroyed it. It's about $500 brand new. You can unplug MAF and car will run a little rough, but will have more horsepower when flooring it. You will also go through a lot of fuel.
Fixed the MAF issue, it didn't have any 12v. That fixed it running too rough, and now it runs too lean.
Did some vac tidy up today, no leaks, started doing the oxygen sensor wiring and just... Gah. I am just getting a custom ecu come the spring, I give up. I've had this car for 6 years and I finally give up on the stock ECU. It's a long time coming.
Link atom 2 kit for the 1uz costs 680-780 GBP. I am gonna get it in the spring. Can't be asked to muck about with this ECU any longer.
Thanks for everyone's help but due to personal reasons I will be losing my marbles.
Custom ECU and tune is probably the best bet.
The stock ECU's are just too old and unreliable if you plan to keep the vehicle in my opinion.
But when these issues still happen after getting the new ECU, you will be most annoyed.
Is the ECU the correct ECU for your vehicle? Did previous owner change it on you?
Perhaps call a qualified auto elec, get a quote, and go from there? They are under warranty and have a national data-base.
My 1991 JDM Soarer came with a "29" ecu. It now runs a "30" ECU from some other vehicle.
If I do not tell the new owner, he may never realize it is not the original ECU for example.
I have seen ECU's put in wrong cases in the past as well.
If ECU is not from your car originally, it possibly throws out errors as the JDM/USA parts are slightly 'different'?
I think, but not totally sure, that the SC400 uses a different MAF to the Soarer V8... JDM being Karman Vortex?
Throttle position sensor is responsible for lean/rich mixture, as well as idle, and gearbox shift operation.
If misaligned or dead, you will have the issues you say. Unsure if it will give you an error on dash. *Water temp sensor doesn't*.
If you know what TPB is, the soarer bible is available there.
Good luck!
