1uz stroke vs 2uz stroke?
i finally found that out on my own, but thanks though. i am using a 1uz block, rods, and pistons, and a 2uz crank. i will ahve to have my piston tops machined down.
On this site elsewhere, in the comparison of the 1uz 2uz and 3uz rods, all were exactly the same length. Is this correct? Then the bigger stroke is because of a different piston size right?
Nath
Nath
Yes the rods are the same length and the stroke is different. The piston pins are at a different location on the pistons. eg: 1uzfe pistons taller than 2uzfe pistons.
