Hey guys finaly got my 1uz in my toyota pickup and solid axle swap done. I have a 3vz fuel pump in a plastic tank right now the engine seems to run fine at low rpm at moderate throttle but if I open it up it will only rev to about 4500rpm with no load on as soon as I stepon it in gear maybe 3000rpm max could it be running out of fuel or did I maybe wire something wrong. in neutral at 1/4 throttle it will rev freely to 6200rpm more throttle and it dies out. the feul pump is on a switch not the ecm.
Also can someone tell me the resitance of the resistor for the factory 2 speed fuel pump
Thanks, Blaine
Thanks, Blaine
