1UZ left hand coil relocation.
361UZ
Hi All.
I am tidying up the front of the 1UZ. I want to move the wires that go to the crank angle sensor from where they currently go, across the left hand cam belt lower cover etc, to under the left hand spark plug lead cover, and down the engine side.
I intend to run the wires over the camshaft bearing, and under the spark plug lead cable tray.
My question is, does anyone know if the proximity to the plug wires will induce spikes/noise etc in the crank angle sensor wiring, and so upset the ECU?
It's ok as long as the ignition system is ok. Otherwise, unwanted interference results as you mentioned
