G'day
I have been lurking here for a while planning my next build and have a few questions but first I will give you an idea of what I am planning. My critera for this build where to be a Hilux dual cab
, be great off road, and be comfortable enough to take the misses and kidlet on weekend trips away camping, have enough power on the highway to actually overtake someone without needing a 500m long runup like I do in my 2.8L diesel hilux.
So the plan I have come up with that also fits easiest into the New South Wales (Australian state) rules is to get an 80 series landcruiser chassis with diffs and suspension etc. This will mean that the suspension will all be off the shelf items. Because I also want a hilux a 2wd hilux body (cheaper than buying a 4wd) will be mounted onto of the chassis. Bonus of this is that I also end up with diffs that are approx 6inches/150mm wider than the standard diffs which will make it more stable off road.
The reason I have been lurking here for a while is I would like to fit the 1uz as it is a great fit in the hilux engine bay as well as being a great performer, and being toyota keeps it all in the family and look factory fitted.
Now I have a few questions
1. I need to run a landcruiser transfer case which has an offset rear drive shaft. The 100 or 105 series landcruiser came out with a r series box mated to a landcruiser transfer case. Would something like this be the best box to run or would a H series (physically much bigger box I believe) gearbox which seem to be much more common but have no idea if I can get a bellhousing to the 1uz
2. If I went the R series box from a 100/105 cruiser which are originally bolted to a 2uz does the bellhousing bolt to a 1uz?
I am sure that there will be far more questions
James
James
