1uz ignition boots for larger cable
jad
Hi
I am megasquirting my engine and have been looking for ignition boots for the 1uz that can take larger diameter ignition leads. Does anyone know of any? I am based in the UK so a source here would be good but anywhere would be handy...
Thanks for your help
Jad
I need the same thing, and also in the UK, purely as I need to run longer leads to the coilpacks I'm running. 1.2m for the longest few leads...
Stock boots/caps are 150mm tall, and I can't find anything like that, find 120mm max, which would still be far from ideal for pushing them securely on to the plugs, and the stock ones don't seem to come apart to re-use them even if I wanted to.
A few years ago I had a set made up that were 1UZ one end and LS1 the other.
I was using LS1 coils remotely mounted and the wires were around 8mm in diameter.
It all fitted nicely.
The leads were made by an organisation in QLD Australia.
I think these are the guys.
Queensland Ignition Leads
1560 Anzac Avenue
4503 Kallangur
Queensland
Phone: (07) 3204 6480Phone: (07) 3886 5700Fax: (07) 3204 6480
I know you want an email address.
All I can suggest is go to this site;
http://www.truelocal.com.au/business/qld-ignition-leads/toowong
and email them from there.
