1uz Hilux overheating with aircon on?
When the A/c is on you have the a/c radiator infront of the Engine radiator heating up the air going through the main Radiator. Main reasons for overheating when a/c is on is limited airflow and radiator being too small. I would check the fins of both the a/c rad and engine rad are not blocked , that there are no restrictions to airflow like number plates , bumpers , plastic gaurds and then that the engine radiator is not blocked internally and then upsize the radiator. Cheers
Ahh ok. I got spotties and winch on front bar so that might not be helping. I've only got a 14" fan so i might try to fit a 16" and see how that goes. Not much room there to fit one but. Few bugs stuck in the small radiator at the front to so ill give that a clean aswell. Thanks mate.
